Jlew04
Oct 18, 2024Aspirant
RBR 750 in AP mode, need changed back to router
I changed my orbi router to AP mode based on the picture you guys gave me it would be best for the system. Then I lost all my Wi-Fi. I cannot connect back to the orbi. I want it back in router but can...
- Oct 18, 2024
Yes, definitely. Factory Reset returns the router to 'router' mode.
p.s. The router web page should still be available if you can connect to the IP address of the router. If the problem is caused by there being no DHCP server to issue IP addresses (AP mode disables the DHCP capability), then the Factory Reset is definitely the right step.
CrimpOn
Oct 18, 2024Guru - Experienced User
