wheatt
Sep 19, 2022Aspirant
RBR 750 intermittently crashes with high load on ethernet
I've tried repeatedly searching and see this problem mentioned, but I've yet to see a solution. I've got an RBR750 (latest firmware, +2 wired satellites) connected to a CM1100 cable modem with gi...
Sep 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are the RBS ethernet connected to the back of the RBR or is there a LAN switch in between?
Having 2.5Gb ethernet adapter may not be recommended as the 7 series system doesn't support 2.5Gb connections. Try setting these adapters to 1Gb max connection rate if you can on these adapters.
Try using 1Gb ethernet supporting adapters.
I've got an RBR750 (latest firmware, +2 wired satellites) connected to a CM1100 cable modem with gigabit internet via Spectrum. Everything mostly works well, but I've noticed intermittent crashes when using my desktop computer connected via ethernet.
This seems to happen with high-bandwidth activities such as running Speedtest.net or downloading via Creative Cloud. It's doesn't happen all the time, but when it does happen its been during one of these activities.
I've tried 4 different NICs.
1. No name brand Realtek 2.5g - same problem
2. Technet Realtek 2.5g - same problem
3. USB Realtek 2.5g - does not have this problem
4. Motherboard (ASUS x570 Prime Pro) Intel i221 - I don't think it had this problem, but I ditched this NIC because it was dropping the internet connection repeatedly for a split second (which is the reason why I changed NICs). Though thinking back I wonder if connection losses I've had in the past were the same issue.
So using a USB Realtek NIC seems fine? I can't for the life of me figure out what's going on. I guess I can keep using the USB NIC, but I'd like to get to the bottom of this.
This is totally a first-world problem but I'm on the verge of ditching the Orbi or buying a separate router and just using the Orbi as an AP.
- wheattSep 20, 2022Aspirant
I'm on the latest 4.6.9.11 firmware. I'm using a Netgear CM1100 cable modem. I have a switch between the router and the satellites - but my computer is connected directly to the router.
Thanks for the advice, I will try Cat6 cable and setting the adapter speed to 1gig rather than auto. Will report back!
Meanwhile I am shopping for a dedicated router like the Mikrotik RB5009, but unfortunately (or maybe fortunate for my wallet) they're impossible to find right now.
- FURRYe38Sep 20, 2022Guru - Experienced User
What is the brand and model# of this swtich between the RBR and the RBS?
Does the RBR still stop working under high load if you turn OFF the switch and the RBS with your wired PC connected to the RBR?
Please configure the 2.5Gb adapter do that it forces a 1Gb connection on the adapter, not auto detect speed.
What are you doing go cause this high load? Streaming or downloading games?
The switch I'm using is a Netgear GS316. I've had it for a few years and it has always run perfectly as far as i can tell.
I haven't tried turning off the switch (pretty much my whole house is wired through it, except for my desktop PC), but I'll give it a go.
I've tried setting the adapter to 1gb without any change.
I've seen the internet connection loss under two scenarios.
1) When running speedtest.net. The connection drops just as the download speed is ramping up. The only way to get the router up and running again is to unplug and replug the RBR750.
2) When updating via Adobe Creative Cloud
Again I know it's a total first world problem. I guess "just don't run speedtest" is one solution, but it is annoying to not being able to figure this out/stop it.
