wheatt
Sep 19, 2022Aspirant
RBR 750 intermittently crashes with high load on ethernet
I've tried repeatedly searching and see this problem mentioned, but I've yet to see a solution. I've got an RBR750 (latest firmware, +2 wired satellites) connected to a CM1100 cable modem with gi...
wheatt
Oct 03, 2022Aspirant
Thanks everyone for the suggestions.
In the end I reverted back to my motherboard's onboard intel 1gig NIC (Intel) and the instability problems went away.
I guess it may have been a compatibility issue with the 2.5gig NIC (Realtek)?
Interestingly, the USB 2.5 gig NIC (Realtek) I tried had no problems.
A little disappointed, but the issues i was having with the 1gig Intel NIC that led me to try a different NIC have seemingly resolved somewhere among all the tinkering.
I guess mark this as (sort of) resolved.
Thanks!
ekhalil
Oct 03, 2022Master
Just a question please:
Just in case! In the Internet settings, what settings do you have for “WAN Preference”:
(1) Internet Port (2.5 Gbps)
(2) WAN aggregation (2.5 Gbps + 1 Gbps, LACP-IEEE802.3ad)
If you don’t use aggregation then you should use option 1.
- wheattOct 03, 2022Aspirant
The RBR750 only has 1gbps, but I tried both (link aggregation and without - my cable modem supports it). I don't think it had an effect. Thanks for the suggestion though.
I actually turned off link aggregation because I think there's a bug when connected to a CM1100, where the speed of the connection slows down after a few days (at least that's what i could gather from my google search).
