wheatt
Sep 19, 2022Aspirant
RBR 750 intermittently crashes with high load on ethernet
I've tried repeatedly searching and see this problem mentioned, but I've yet to see a solution. I've got an RBR750 (latest firmware, +2 wired satellites) connected to a CM1100 cable modem with gi...
ekhalil
Oct 03, 2022Master
Just a question please:
Just in case! In the Internet settings, what settings do you have for “WAN Preference”:
(1) Internet Port (2.5 Gbps)
(2) WAN aggregation (2.5 Gbps + 1 Gbps, LACP-IEEE802.3ad)
If you don’t use aggregation then you should use option 1.
wheatt
Oct 03, 2022Aspirant
The RBR750 only has 1gbps, but I tried both (link aggregation and without - my cable modem supports it). I don't think it had an effect. Thanks for the suggestion though.
I actually turned off link aggregation because I think there's a bug when connected to a CM1100, where the speed of the connection slows down after a few days (at least that's what i could gather from my google search).
