cjlutz
Dec 12, 2021Aspirant
RBR 750 Problem
My Orbi RBR 750 Router is not connecting to my ISP modem. I've tried all of the troubleshooting methods without success. On the Orbi Iphone app I get an "orbi not found" message. I've tried a factory...
Yahey
Dec 13, 2021Aspirant
Hello Cjlutz,
Thanks for the prompt feedback.
My ISP box (fiber). Orange Box.
The box has its own IP range.
The ORBI has another one.
- FURRYe38Dec 13, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Yahey wrote:
Hello Cjlutz,
- cjlutzDec 13, 2021Aspirant
Thanks for feedback. Not sure I have the confidence to do that without screwing it up. The wifi through the modem works...just don't have the same range. Why do you think it suddenly stopped working?
Contact your ISP to have them help you with the modem.
If both modem and orbi wifi are running, noise and interferences between each other can cause problems. Why it's recommended to run only 1 wifi system in a household.
