bsider
Apr 11, 2024Aspirant
RBR 750 Shuts Off
My Orbi RBR 750 shuts off at a specific time each day. Is there a setting with the Orbi that i need to shut off to keep the Orbi online.
- Apr 16, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 11, 2024Guru - Experienced User
What do you mean by shuts off?
Orbi systems are ON and online all the time, 24/7. Unless you have a power issue or something else happening here.
Is the back LED on the RBR ON or OFF when you see this? GREEN in back is operating normally.
Any front LED indications?
Try a different wall outlet or power strip?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
bsider
In the Orbi Log I get the following about nightly and the Orbi disconnects.
Internet disconnected] Thursday, Apr 11,2024 09:37:56
[DHCP IP: (192.168.1.13)] to MAC address CE:81:19:A5:12:F4
There orbi just shows offline. There is not a power strip in play.
It happens about every 24 hours to the minute.
- FURRYe38Apr 11, 2024Guru - Experienced User
What is the size of your home? Sq Ft?- CrimpOnApr 11, 2024Guru - Experienced User
There is not a user setting that determines when the Orbi is connected to the internet. "Always" is the default.
It is typical for Internet Service Providers to assign the IP address lease to customer accounts for 86,400 seconds (one day). The next time this happens, could you log into the Orbi, navigate to the "Internet" page and select the "Test" option at the top of the page:
- bsiderApr 11, 2024Aspirant
Hardware Version RBR750 Firmware Version V4.6.14.3_2.3.12 Comcast: Modem PC 20 and ES 2251 are on the black box. Doesn't really show a model number
1 satelite
So this shows that the RBR disconnected from the modem or the ISP modem disconnected from the RBR or the ISP modem stop providing services to the RBR.
Is the front LED on the RBR turning ON PINK or Blinking WHITE when this happens?
Those are cable modems and are always ON which the RBR defaults to ALWAYS ON. The RBR just depends on getting a good signal from the ISP modem.
Also your system is behind on FW as well:
Once the ISP signal and modem have been checked, might update the Orbi system.
[DHCP IP: (192.168.1.13)] to MAC address CE:81:19:A5:12:F4There orbi just shows offline. There is not a power strip in play.
