bsider
Apr 11, 2024Aspirant
RBR 750 Shuts Off
My Orbi RBR 750 shuts off at a specific time each day. Is there a setting with the Orbi that i need to shut off to keep the Orbi online.
- Apr 16, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 16, 2024Guru - Experienced User
Any progress on this?
- bsiderApr 16, 2024Aspirant
Upgrade cable to 6e and all issues went away.
Thanks you for the help.
- FURRYe38Apr 16, 2024Guru - Experienced User
Enjoy. 📡
