bsider
Apr 11, 2024Aspirant
RBR 750 Shuts Off
My Orbi RBR 750 shuts off at a specific time each day. Is there a setting with the Orbi that i need to shut off to keep the Orbi online.
- Apr 16, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
bsider
Apr 16, 2024Aspirant
Still trouble shooting. I had a couple days of no issues. then yesterday 3 times.
Apr 16, 2024Guru - Experienced User
Is the front LED on the RBR turning ON PINK or Blinking WHITE when this happens?
Those are cable modems and are always ON which the RBR defaults to ALWAYS ON. The RBR just depends on getting a good signal from the ISP modem.
