NeoVN
Jun 17, 2024Aspirant
RBR 750 update firmware 7.2.6.31 - 500 Internal Server Error
My Orbi system is RBR 750 and 3 x RBS 750. RBR was using as router. 3 x RBS connected with RBR using wire. I was using fine when loading firmware 4.6.11.1 Few day ago. I tried to update firmware ...
CrimpOn
Jun 17, 2024Guru - Experienced User
Did you choose to set the Orbi LAN to IP subnet 192.168.11.x?
This is not the typical configuration for Orbi routers. Certainly legitimate (all 192.168.x.x address are available as 'private' IP subnets.) but unusual.
