NeoVN
Jun 17, 2024Aspirant
RBR 750 update firmware 7.2.6.31 - 500 Internal Server Error
My Orbi system is RBR 750 and 3 x RBS 750. RBR was using as router. 3 x RBS connected with RBR using wire. I was using fine when loading firmware 4.6.11.1 Few day ago. I tried to update firmware ...
NeoVN
Jun 20, 2024Aspirant
The issue was not sloved.
I was hard reset my system to default.
Upgrade RBS to v.21. After that I upgrade my RBR to v.21.
I can login to all of my RBS. Only when I try to login to my RBR. I got this problem.
500 Internal Server Error.
This happen when I from ver 4.x.x.x upgrade to 7.x.x.x
Now I will try to hard reset to downgrade to 4.x.x.x . Let's see this issue had been solved or not.
Jun 27, 2024Guru - Experienced User
Any progress on this?
