LIKHIL
Oct 10, 2023Follower
RBR 750 WAN port is not connecting with modem
Hi, I am using an RBR 750 model router, and this router's WAN port is not working, checked with another router, and it's working fine and checked the port with the LAN checker its lights are show...
Oct 10, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
