RJM_5
Aug 22, 2021Aspirant
RBR 750 will not connect to Cable Router after a power fail, requires RBR750 to be power sequenced.
After a power outage the RBR750 will not connect to a ARRIS cable router. The RBR750 needs to be power cycled (disconnect power then connect power), which corrects the problem. The Orbi is installed ...
tucsontico
Aug 22, 2021Virtuoso
I also have an Obri at a remote location (vacation house). The simple solution to your problem is to get a battery backup (Uniterruptible Power Supply-UPS) that has enough power to handle both your Orbi and the cable modem. However, that may not solve every glitch. My remote ISP has a poor reliability record and internet access drops out at least once per week–it may be for minutes or hours.) A UPS will not solve that problem.
I do have my modem and router connected to a UPS, but I also invested in a two outlet remote power switch like this one: https://5gstore.com/product/8897_2_outlet_ip_switch.html. This outlet can be configured to reboot both the cable modem and router if either loses connectivity. Works well for me and worth the $100, IMO.
Good Luck!
RJM_5
I did testing with both the cable router and Orbi router:
>Cable router takes 60 seconds to on-line status
>Powering on the Orbi 60 seconds after the cable router is powered on , is one solution.
I will install the outlet that was provided in your link, thanks!
I believe a second solution would require a firmware change, but not knowing the code this
could be wishfull thinking.
- tucsonticoAug 23, 2021Virtuoso
RJM_5 wrote:I did testing with both the cable router and Orbi router:
OK. Consider that, if the power goes out, the remote outlet will quit too. When the power is restored, the outlet may not reset with the timing you specified (60 second delay). It may be added expense, but a UPS between the main power and the remote outlet will give you higher confidence (nothing is 100%) you can reset the modem and Orbi in the proper sequence. Good luck with the remote reset outlet.
