RJM_5
Aug 22, 2021Aspirant
RBR 750 will not connect to Cable Router after a power fail, requires RBR750 to be power sequenced.
After a power outage the RBR750 will not connect to a ARRIS cable router. The RBR750 needs to be power cycled (disconnect power then connect power), which corrects the problem. The Orbi is installed ...
Aug 22, 2021Guru - Experienced User
RJM_5 wrote:
After a power outage the RBR750 will not connect to a ARRIS cable router. The RBR750 needs to be power cycled (disconnect power then connect power), which corrects the problem. The Orbi is installed in a remote location and be able to recover
from the power outage without the manual power cycle.
- RJM_5Aug 23, 2021Aspirant
Data you requested-
Cable Router:
ARRIS(Motorola)
Model SBG6580-G228
Software version SBG6580-6.5.0-GA-NOSH
WIFI Router:
Netgear(Orbi)
Model RBR750
Firmware version V4.6.3.7_2.0.49
Orbi Sat_1
Model RBR750
- FURRYe38Aug 23, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
