RJM_5
Aug 22, 2021Aspirant
RBR 750 will not connect to Cable Router after a power fail, requires RBR750 to be power sequenced.
After a power outage the RBR750 will not connect to a ARRIS cable router. The RBR750 needs to be power cycled (disconnect power then connect power), which corrects the problem. The Orbi is installed ...
RJM_5
I did testing with both the cable router and Orbi router:
>Cable router takes 60 seconds to on-line status
>Powering on the Orbi 60 seconds after the cable router is powered on , is one solution.
I will install the outlet that was provided in your link, thanks!
I believe a second solution would require a firmware change, but not knowing the code this
could be wishfull thinking.
tucsontico
Aug 23, 2021Virtuoso
RJM_5 wrote:I did testing with both the cable router and Orbi router:
OK. Consider that, if the power goes out, the remote outlet will quit too. When the power is restored, the outlet may not reset with the timing you specified (60 second delay). It may be added expense, but a UPS between the main power and the remote outlet will give you higher confidence (nothing is 100%) you can reset the modem and Orbi in the proper sequence. Good luck with the remote reset outlet.
