JSJ34
Jan 16, 2021Aspirant
RBR 750 will not connect to NUVO Music System
RBR750 does not allow my NUVO Music System to access network when plugged into port. Our ORBI RBR 750 works perfectly with all wireless devices including MyQ, ecobee, Ring etc. It also work...
Jan 16, 2021Guru - Experienced User
What happens when you connect this one device directly to the back of the RBR with out this switch in the mix?
What is the mfr and model # of this ethernet switch?
JSJ34
Jan 17, 2021Aspirant
Thaks for your communication.
Orbi still doesnt recognize either device when plugged directly into the port bypassing the switch.
We tested the switch with other devices like my laptop and my Control 4 CPU it it work fine.
I am concerned there is some sort of IP conflict. My sound system and security technician and i called in for support as the system is still new and after 40 minutes of struggling with the communication barrier with the Netgear rep decided to give it a rest and use the cse number to try to fix it again tomorrow or tuesday.
- FURRYe38Jan 18, 2021Guru - Experienced User
Can you set a static IP address on this device? Is there any kind of networking configuration settings or is it all automatic?
