JN_AB
Nov 17, 2023Aspirant
RBR 750 wrong subnet mask
My Orbi RBR 750 WAN setting says my subnet mask is 255.255.252.0 Yet my ISP modem says 255.255.255.0 on ipconfig/all its 255.255.255.0 Why? will this be a problem and how do i change it on the...
Nov 17, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
The RBR auto detects what ever comes from the ISP only. If the ISP is putting out 255.255.252.0 then they will need to make the change from there side.
Also IPCONFIG /All only shows subnet mask on what's used on the LAN side.
- JN_ABNov 17, 2023Aspirant
Firmware Version
V7.2.6.21_5.0.20XB7 Arris modem
Cat 6 cables
- FURRYe38Nov 17, 2023Guru - Experienced User
Those modems are typically built with a router with in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- JN_ABNov 17, 2023Aspirant
ISP modem is in bridge mode
all was working fine up until 2 weeks ago
I will contact the ISP They maybe of changed the subnet mask? not sure
One point maybe is I have connected to a trendnet TPE 3524sf ) it has a static ip
Would this be the issue?
