JN_AB
Nov 17, 2023Aspirant
RBR 750 wrong subnet mask
My Orbi RBR 750 WAN setting says my subnet mask is 255.255.252.0 Yet my ISP modem says 255.255.255.0 on ipconfig/all its 255.255.255.0 Why? will this be a problem and how do i change it on the...
JN_AB
Firmware Version
V7.2.6.21_5.0.20
XB7 Arris modem
Cat 6 cables
Nov 17, 2023Guru - Experienced User
Those modems are typically built with a router with in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- JN_ABNov 17, 2023Aspirant
ISP modem is in bridge mode
all was working fine up until 2 weeks ago
I will contact the ISP They maybe of changed the subnet mask? not sure
One point maybe is I have connected to a trendnet TPE 3524sf ) it has a static ip
Would this be the issue?
