Bru358
Dec 18, 2024Aspirant
RBR 760- IP Communication
Hi, have an energy meter from Accuenergy for monitoring and controlling my household battery. For communication, Modbus TCP/IP is used. The meter is connected via ethernet cable directly to the Orbi ...
Bru358
Hi need to update the case with some more information. After a little more research, I can see with the help of the Angry IP scanner that the meter loses connection and goes offline immediately after restarting the router or meter. I.e. the entire IP address is offline and cannot be reached or pinged. No communication via Modbus/IP. When I plug in and out of the cable, the device (usually) goes online again. No other wired devices have similar problems.
Thanks
