snoopypc
Apr 23, 2025Aspirant
RBR 850 Access Control auto turn on
my router block my google hom max automatic I turn it off and with in tem min it is blocked again any ideas
snoopypc
I login to the router thru the IP address and goto the access control and trun it off and click on apply
CrimpOn
Apr 23, 2025Guru - Experienced User
Suggestions:
- Access Control has three tables of MAC addresses:
- Devices that are currently connected to the network.
- Devices that are not currently connected and have been defined as Allowed.
- Devices that are not currently connected and have been defined as Blocked.
- Can you scroll down and ensure that this specific device does not appear in any of the tables?
Do you ever use the Orbi 'app'? I had a horrible experience once when a device was suddenly 'blocked', and I never enable Access Control. After much swearing, the final conclusion was that I must have somehow 'swiped' that green slider next to the device to "Pause" it.
