Retired_Member
Nov 14, 2023RBR 850 All internet Slower Than Input
I have an RB or 850. All of a sudden I am losing network speed. When connecting the ethernet cable directly to the input side of the router I am getting nearly 1 Gb speed when I plug it into the rout...
Nov 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Retired_Member
Nov 14, 2023using Cat8 cables LIKE I SAID !!! input to the router (orbi rkr 850) is nearly a gigabit but the out put is only 100 megabit the router is losing 90% of its speed and it is LOST AT THE ROUTER
- FURRYe38Nov 15, 2023Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What device are you speed testing with AT THE ROUTER?
Try a different ethernet connected PC connected AT THE ROUTER to compare results.
