chucko73's avatar
chucko73
RBR 850 and RBS 850 - What is correct firmware at this point to enable web login after recent issues
I did a reset and was able to login briefly (on 5/15). I am able to access by Orbi App on android. No joy on iPad App or PC web browser. Before I do a full reset again, I thought I should ask.... what firmware version should I be looking for on the units? Right now the Orbi App reports 4.6.8.2 on RBR and 4.6.3.16 on both RBS.
I am guessing that there is a right version and that I need to get it on all of the satellites as well...?
Network is functioning but I am not able to get into restoring static IPs etc... and I know that things aren't right.
The Orbis have been great for almost 2 years, but this problem comes at a really bad time. (No surprise)
Thanks in advance
  • FURRYe38's avatar
    Do you still have v.2 FW files by chance?
    I know NG pulled the v2 version however we believe that's working if manually installed.
    If your RBR is at v2 and the RBS are at v.16, I guess grab the RBR file for this version and down grade to it. Another user mentioned they downgraded and had no problems.
    I recommend that when you do, get the file on a local wired PC first. Disconnect the RBR from the ISP modem or ONT.
    Factory reset by pressing the reset button for 15-20 seconds, then release.
    Use MS Edge, FireFox or Opera and point to HTTP and 192.168.1.1. This should bring up the Orbi app screen on the browser. Scroll down to the bottom and select don't have a mobile device. Should start the setup process. You can go thru the process with out having the RBR connected. Once at the home screen go in and send the v.16 RBR FW file that you unpacked from the .zip file.
    • L1Wulf's avatar
      L1Wulf
      Completely anecdotal and I only came across this AFTER stumbling through things on my own...
      I am on v.2 and had been noticing a LOT of random issues but hadn't tried logging into my RBR850 until recently (a week or so).  I managed to log in and immediately made a backup of my settings then started pouring through settings and logs.  A lot of things seemed off.  Strange devices connected -- at least there seemed to be strange devices based on names.  I have reserved IPs for everything (which is A LOT of devices) and I noticed devices were connected to reserved IPs but with different names.  OK, really strange... I wanted to better understand what might be going on -- was I hacked? Did the router glitch? No clue.
      I didn't have the time to mess with things at that time.  I did a reboot and the issue I was seeing (streaming TV) cleared up.  Skip forward a couple of days and I returned to take another quick look.  Weirdly, my satellites were showing disconnected.  But I knew I had devices connected to WiFi on those devices (one wired backhaul the other WiFi) and those seemed to be working fine.  I dug around some more but couldn't understand what was going on.
      Today I determined I would just do a complete reset and either manually restore or use my backup.  I couldn't log into the RBR850.  Reboot.  Nope. Unplug and sit for 5 minutes for both modem and router.  Now I lost internet and still couldn't log into the router.  Great.
      I took a pin and did a hard reset on the RBR850 (pressed for about 5-10 seconds - waited until the power light started flashing).  After a while I was able to see the setup page. I used the Orbi app (Android), removed my old device config and clicked on New Setup.  This went smoothly but it failed to detect my satellites.  I took the pin and hard reset these and rescanned.  Bingo.
      After I finished the configuration I went ahead and restored from my backup with the thought that if things go south, I'll just repeat the process and reconfigure by hand.
      It's been about an hour and everything seems to be back on point - still on v.2.
      Not sure if this will help anyone, but if you're completely stuck, it's worth a shot.
      • FURRYe38's avatar
        FYI, it's recommended to press the reset button for 15-20 seconds then release. This ensures to trigger the full on factory reset.
