gerardw
Sep 04, 2021Initiate
RBR 850 device connectivity
I briefly tried another router, but was unhappy and went back to my Orbi RBR 850. Some devices (Sonos sound system and security camera system) no longer connect to my Orbi router. They don't show up...
EagleLanded
Oct 01, 2021Star
Everything is totally unreliable at the moment with RBK850 after the forced FW update (not tested by NG and fully of critical issues. Writing this comment I get constantly kicked off the Wifi. Data in the IOS app is not thrustworty either, and directly false. My wireless iphone and iPad shows as cabled. You cannot thrust was FW version you in reality are on and so forth. So no wonder that you are experincing these connectivity problems. No responses at all official from Netgear - of course. Incompetent product management. Probaly Agile development - where they forget QA. Look around in the community - it is a mess
Oct 01, 2021Guru - Experienced User
Please make a new post and include all of your information and will see if we can help you get yours running better. This thread is mostly solved and is regarding also a SONOS system as well.
So lets post a new topic for you and will go from there.
Its already known there are problems with v4.
Thank you.
