dsingerUNC
Sep 23, 2021Aspirant
RBR 850 firmware update 4.6.3.16
I have 1 RBR850 with 4 RBS850s that are hard wired to the RBR850. The app prompted me to upgrade to 4.6.3.16 today, which I did. However, only the RBR850 and 2 of the 4 RBS850s upgraded. The other tw...
Sep 23, 2021Guru - Experienced User
Can you access the RBS web page using there IP addresses seen on the RBRs web page?
- dsingerUNCSep 23, 2021AspirantI cannot. It just is blank - same as when I try to click the manual firmware update on each one.
- FURRYe38Sep 23, 2021Guru - Experienced User
Downgrade the RBR back to v9. Then see if you can connect to the RBS. If so, manually send the v16 update. After that re-udpate the RBR lastly.
Will give that a try.
