Chuck_M
Dec 06, 2019Mentor
RBR 850 Firmware V3.2.8.5_1.2.3
This afternoon I noticed a new version of firmware had been installed on my RBR850 as well as the RBS850. I was on the road when I had ran the Orbi app and noticed the router was "red" although I...
Dec 09, 2019Guru - Experienced User
Ok lets get your modem configured first since it already has a built in router that maybe interferring with the update process. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Once you use one of the options above, try and upgrade the RBS first then try to update the RBR lastly.
dan_ro_ga wrote:The satellite shows that number during to attempted download, but the main router fails, so it fails the process. I'm the one with the ATT Pace 5286AC router. I have had to reboot the RBR850 twice now due to it 'freezing up' and not communicating. I'd like to try the new firmware before I return this to BB for a fulll refund.
dan_ro_ga
Dec 09, 2019Tutor
Thanks, but the ATT modem is configured properly, and has worked for years with the previous NG routers. This is an Orbi issue alone, and it might be a hardware issuet, or a firmware issue, but since they don't seem to want to release the v3.2.8.5 version, I'm guessing there were other issues with it as well since its been nearly a week since support told me about the new release, but didn't share a link to get it. frustrating...
