Chuck_M
Dec 06, 2019Mentor
RBR 850 Firmware V3.2.8.5_1.2.3
This afternoon I noticed a new version of firmware had been installed on my RBR850 as well as the RBS850. I was on the road when I had ran the Orbi app and noticed the router was "red" although I...
dan_ro_ga
Dec 09, 2019Tutor
Thanks, but the ATT modem is configured properly, and has worked for years with the previous NG routers. This is an Orbi issue alone, and it might be a hardware issuet, or a firmware issue, but since they don't seem to want to release the v3.2.8.5 version, I'm guessing there were other issues with it as well since its been nearly a week since support told me about the new release, but didn't share a link to get it. frustrating...
Dec 09, 2019Guru - Experienced User
So what proper configuration is the modem in? Would need to know this? I presume it's in router mode and your using IP-Pass-thru or DMZ? Kind of helps us to know what the modem mode is before we can continue. Just because it worked on other routers doesn't mean others will. We do want it to work of course. Just verifing the mode here is all. Having a router in front of the RBR can cause these kinds of problems.
If anything you might contact one of the forum moderators to see if you can gain access to the updated FW files.
Be sure to try the update via the RBRs web page. Don't use the Orbi app.
dan_ro_ga wrote:Thanks, but the ATT modem is configured properly, and has worked for years with the previous NG routers. This is an Orbi issue alone, and it might be a hardware issuet, or a firmware issue, but since they don't seem to want to release the v3.2.8.5 version, I'm guessing there were other issues with it as well since its been nearly a week since support told me about the new release, but didn't share a link to get it. frustrating...
- dan_ro_gaDec 09, 2019Tutor
its in the DMZ+ mode where all traffic is forwarded through the ATT into the Orbi. And you can see it in the Orbi since the external IP is passed through and shows on the orbi screens.
.. - FURRYe38Dec 09, 2019Guru - Experienced User
Yes that should work for you. Just making sure.
I would make contact with one of the forum moderators and see if they can get you the FW files.
dan_ro_ga wrote:its in the DMZ+ mode where all traffic is forwarded through the ATT into the Orbi. And you can see it in the Orbi since the external IP is passed through and shows on the orbi screens.
.. - Blanca_ODec 09, 2019NETGEAR Employee Retired
Hi, All,
Here's the link to download RBK852 firmware v3.2.8.5_1.2.3
The said firmware will be posted on our support site.
Blanca
Community Team - dan_ro_gaDec 10, 2019Tutor
Thanks, I loaded it this morning and it didn't make a difference. Amazon Prime Video continues to have the same problem, wired directly or wireless, it made no difference, still seems like a buffering issue. I did get an email from support requesting more time to resolve the issue, so I think they are aware, and I'm not the only one having this issue...my guess only, they didn't say that, but a guess... I'll try to go a few more days...
- FURRYe38Dec 10, 2019Guru - Experienced User
Do you load the FW and continue or load FW and factory reset and setup from scratch?
dan_ro_ga wrote:Thanks, I loaded it this morning and it didn't make a difference. Amazon Prime Video continues to have the same problem, wired directly or wireless, it made no difference, still seems like a buffering issue. I did get an email from support requesting more time to resolve the issue, so I think they are aware, and I'm not the only one having this issue...my guess only, they didn't say that, but a guess... I'll try to go a few more days...
I just loaded the FW and made sure the satelite was updated, and then I did a reboot. I have to work today, as does my wife, so I didn't try a factory reset and rebuilding the settings. I might try that later when we aren't working to see if it helps. My wife is quite irritated since the orbi drops her voice on conference calls at random times....
-Dan
Understand. Yes, please try a factory reset and setup from scratch when you get time.
What is the Mfr and model# of the ethernet switch in the configuration?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerTry setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I know you want to to work in router mode, however as a last resort you can remove the DMZ+ configuration from the modem and configure the RBR for AP mode to see if there are any improvements.
dan_ro_ga wrote:I just loaded the FW and made sure the satelite was updated, and then I did a reboot. I have to work today, as does my wife, so I didn't try a factory reset and rebuilding the settings. I might try that later when we aren't working to see if it helps. My wife is quite irritated since the orbi drops her voice on conference calls at random times....
-Dan
