saltiedawg
Aug 21, 2022Aspirant
RBR 850 guest network ssid broadcast
My new Orbi 850 router set my guest network ssid to my network name plus "-Guest". When enabled, my guest network ssid would not broadcast. I removed the hyphen, left it as a space and then the guest...
Aug 21, 2022Guru - Experienced User
- saltiedawgAug 21, 2022Aspirant
FURRYe38,
Router firmware is V4.6.3.16_2.0.51
Modem is Arris model #TM1602A
- FURRYe38Aug 21, 2022Guru - Experienced User
Default SSID name for GN had the (-) dash in the name and works for me on my 7 series. Though I'm later version of FW.
You might update FW:If you do, Ensure you update the RBS first then the RBR lastly.
MIght do a fully factory reset and setup from scratch afterwards if yours still seens this odd issue.
