PersonalJesus1
Jan 01, 2021Initiate
RBR 850 how to Daisy chain
I am looking to daisy chain a satellite 850 to another satelite 850 vs going to the main router. Looking to increase my range. Its my understanding that this is possible, but looking to get insight...
- Jan 01, 2021
Please mark your thread as solved so others will know.
Enjoy.
PersonalJesus1
Chuck_M. You were right. I just needed to set up the 2nd satellite with the main router then move it to the desired location. It automatically daisy chained. Perfect solution. No more dead spot in my back bedroom. Thanks!!
Jan 01, 2021Guru - Experienced User
Enjoy.
