Divay18
Sep 22, 2023Aspirant
RBR-850 keeps restarting
Hi, I bought the router about a year back. Everything was fine it didn't have any issues at all. BUT since tomorrow, it's suddenly died on me. The main router just keeps blinking white light, gives ...
Sep 22, 2023Guru - Experienced User
Try a 30-30-30 reset on the RBR...
- Divay18Sep 22, 2023Aspirant
Thanks for the quick reply.
I tried the 30-30-30 reset. Router starts, I try set it up and within ~2 mins it starts resetting again.
Sequence as follows : -
I do 30-30-30 reset --- router restarts after reset (white led blinking) ---- (white LED Stable) i connect to wifi via app(android) ---- setup via app ----- setup completes (LED is Off now after Solid White while setting up.[no BLUE LED came on!]) ----- Now wifi is connected on my phone, and suddenly within ~2 mins wifi drops and the router is again restarting with blinking white leds.
Nothing is connected to the RBR, I have disconnected the Satellite. Only thing connected to Router is the power cable and the ethernet cable from the ISP(PPPoE).
I tried with ethernet connected to laptop as well. it just gives me about 2 mins of internet after setup from factory reset and then it just keeps restarting
Is there something I'm doing wrong?
- FURRYe38Sep 22, 2023Guru - Experienced User
I guess contact NG support and ask about RMA options:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/- Divay18Sep 22, 2023Aspirant
DAMN!!
I called them
They are telling they'll get back to me within 48 hrs.
I had such high hopes from this setup, giving up after just 1 yr.
