JHB545
Mar 07, 2023Aspirant
RBR 850 location and physical setup
Looking for basic guidance on setting up my mesh network (RBR850: base and two satellites). I have an underground basement, main level and 2nds floor house (i.e. 3 levels totaling about 7000sf) My Sp...
Mar 07, 2023Guru - Experienced User
30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Basements are not recommended placement for the RBR. Concrete and steel will impact wifi signal travel and coverage. You can have a RBS in the basement however wireless maybe lower than desired. If you have a ethernet connection from the RBR to the basement area to the RBS here, then you'll be good.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- JHB545Mar 07, 2023AspirantThanks so much for your reply!
Modem is Spectrum’s Technicolor ET2251
