Jjpa
May 14, 2022Initiate
Rbr 850 no connection with RiseBroadband service provider.
Over a week, not able to connect with Service provider’s router. RiseBroadband service call resulting in clear, strong signal. All other connections work except Router. A direct connection to Orbi sat...
May 14, 2022Guru - Experienced User
If the ISP modem has a built in router already,
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
