jneusch64
Apr 30, 2021Aspirant
RBR 850 Router - add RBS 750 satellite
I saw a previous post about adding an RBS 750 satellite to an 850 system, but the OP was using wired backhaul. I am in a similar situation where I need to add an additional satellite to my 852 syste...
- May 01, 2021
Only connection rates between the connect devcies and the RBS.
Apr 30, 2021Guru - Experienced User
The wireless backhaul is the same, however front haul is just a bit slower in rate on the 7 series than the 8 series. Otherwise the RBS will work fine. Look at the spec sheets for each series to see the differences.
- jneusch64Apr 30, 2021Aspirant
Thanks for the reply. I saw that the 750 is a bit slower, but will it negatively impact the overall wireless speed of the 850 satellite and the router, or only the wireless speed of itself? I don't want to negatively impact the overall system. Glad to hear that the wireless backhaul won't be affected.
- FURRYe38May 01, 2021Guru - Experienced User
