Wilocat
Sep 10, 2021Tutor
RBR 850 see no firware update
After i login to orbi login and i go to firmware update i got the message "No New Firmware Available' (Pressent Firmwareversie V3.2.18.1_1.4.14) but at the moment is the actual newest firmware 4.6....
Sep 10, 2021Guru - Experienced User
Some systems are not made available for auto updates. One can manually update FW:
It's recommended if your system IS working, hold of on upgrading.
- WilocatSep 17, 2021Tutor
Thanks for the answer, its upgraded
- FURRYe38Sep 17, 2021Guru - Experienced User
Let us know how it works for you.
- FarmerBob1Sep 19, 2021Luminary
Wilocat wrote:Thanks for the answer, its upgraded
Any Flames?!
