tbinco
Nov 14, 2023Follower
RBR 850 VPN error with iPadOS 17
I'm seeing an issue ever since I upgraded my iPad to iPadOS 17. Before the upgrade, I was able to connect my iPad to the VPN service on my RBR850 using the standard OpenVPN client. Since the upgrad...
CrimpOn
Nov 14, 2023Guru - Experienced User
tbinco wrote:
Any thoughts on a solution, or should I post this question on an OpenVPN community instead?.
Internet search of "ee key too small" gets lots of hits (mostly from Linux users).
Can you check which version of OpenVPN Connect is on your iPad? (version 3.4.1 was released Nov 9, 2023).
It would not hurt to download another copy of the Smart Phone parameter file from the Orbi and compare it with the existing file. (One would think they should be identical.)
My guess is a problem that affects only iOS is more likely to find a solution in either an Apple forum or the OpenVPN forum.
