louisenslin's avatar
louisenslin
RBR 850 with 2 x sattelites
Hi
I have 2 x satellites in my mesh system with the furthest one about 25 meters from my route with a fair amount of walls in between.
When I connect to the wifi far from the router, the signal is weak and when I log into the Orbi app, it seems like my device connects to the router instead of the satellite. Its both an iPhone and MacBook pro, so it should be 5G. I understand that the orbi satellites don't run 2.4G?
Anyway, so the mesh satellite system seems redundant as nothing connects to the satellites, only the primary router, even if the signal is weaker to the main router as opposed to the satellite.
How do I force devices to connect to the stronger signal (satellite), rather than the router that's far away?
Thanks
  • CrimpOn's avatar
    CrimpOn
    This is incorrect.  Every Orbi unit broadcasts the same SSID on both 2.4G and 5G WiFi channels. There are many apps for Android and Windows (sorry, no experience with "i-things") that will display the actual signal level of each unit.  i.e. when there are one router and two satellites, the SSID will appear three times at 2.4G and three times at 5G.
    The short answer is that the user cannot force a device to connect to a specific WiFi unit.  Software in the device is supposed to compare the available WiFi access points, have a dialog with them about what features they support, and choose the best connection.
    I have observed that my phone tends to connect to the garage satellite as soon as I get out of the car.  I will go upstairs (where I sit now, right next to the router), and notice, "WTF?  What is the phone doing connected at 2.4G???"  Toggle WiFi off and back on, and it connects to the router at 5G.  Phones are supposed to roam, checking constantly for "a better connection."
    Unless my math is rusty, 25 meters is a bit over 75 feet.  Do the satellites show a "Good" connection to the router on the Orbi app network map or the web browser Attached Devices page?
    • louisenslin's avatar
      louisenslin
      HI Guru
      Thanks for your reply.
      Regarding the 2.4 and 5g section, please see my screenshot attached. The sattelites only states 5g? I also just noticed that th backhaul states keep flipping between "good" and " out of sync" I have the latest firmware and rebooted the whole system.
      Then, sorry its 15 meters, not 25. I think the main issue I have it that nothing connects to the satellites, all the devices default to connecting directly to the router, even if the wifi signal right by the sattelite is much stronger that all the way from the router. I assumed that any device will prefer a stronger radio signal?
      • CrimpOn's avatar
        CrimpOn
        I would relocate satellites until they sync and stay synced. I do not see how anything can connect to a satellite that is not synced.
