gursoynecdet
Dec 07, 2023Tutor
RBR 850 with 6 satellites backhaul problem
Hi I ve been using orbi mesh for such a time, I have RBR 850 as a router then 6 satellites connected with ether all over the house The problem is sometimes system shows backhaul on ethernet (good...
CrimpOn
Dec 07, 2023Guru - Experienced User
The most obvious possibility is that the wire connection between router and satellites has been disrupted.
- Is there perhaps a switch involved in the path between router and satellites?
- Do ALL satellites switch from 'wired' to WiFi at the same time?
- Do they ever switch back?
- gursoynecdetDec 07, 2023Tutor
Thanks for quick reply,
three sattelites are connected from the RBR850's ethernet port.
The other sattelites are through the switch. yes sometimes they comeback.
- CrimpOnDec 08, 2023Guru - Experienced User
Netgear says the AX systems support six satellites:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
All six 'wired' should be the optimal structure.
These cable connections are probably going through a patch panel somewhere in the house?
- gursoynecdetDec 08, 2023TutorYes 3 of them is directly connected to the router (rbr850)
The others are connected to the switch directly no patch
