gursoynecdet
Dec 07, 2023Tutor
RBR 850 with 6 satellites backhaul problem
Hi I ve been using orbi mesh for such a time, I have RBR 850 as a router then 6 satellites connected with ether all over the house The problem is sometimes system shows backhaul on ethernet (good...
CrimpOn
Dec 07, 2023Guru - Experienced User
The most obvious possibility is that the wire connection between router and satellites has been disrupted.
- Is there perhaps a switch involved in the path between router and satellites?
- Do ALL satellites switch from 'wired' to WiFi at the same time?
- Do they ever switch back?
gursoynecdet
Dec 07, 2023Tutor
Thanks for quick reply,
three sattelites are connected from the RBR850's ethernet port.
The other sattelites are through the switch. yes sometimes they comeback.
