SBstomper2
Jul 29, 2024Aspirant
RBR 850
I have an Orbi 850 mesh and for some reason its only producing 90 to 100 mbps wifi and when I hook up a pc directly to the ethernet cable coming from the modem I am getting 750 to 1000mbps. I have d...
Jul 29, 2024Guru - Experienced User
have you tried loggin in and checking the hardwired connection links? maybe its not connecting at gigabit speeds.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- SBstomper2Jul 29, 2024Aspirant
I turned off the polling and still the same not sure the issue.
- plemansJul 29, 2024Guru - Experienced User
I have no idea what you mean with this comment.
- SBstomper2Jul 31, 2024Aspirant
I was able to get to the screen in the for statistics and I see where its only showing wan as 100M Full
I have contacted my provider multiple times.
Is there a setting that changed or is that showing the speed from the provider?
