SBstomper2
Jul 29, 2024Aspirant
RBR 850
I have an Orbi 850 mesh and for some reason its only producing 90 to 100 mbps wifi and when I hook up a pc directly to the ethernet cable coming from the modem I am getting 750 to 1000mbps. I have d...
SBstomper2
Aug 01, 2024Aspirant
I have tried multiple cables as stated before I did switch to a cat 6 cable the router is a Hitron Tech EN221 that was replaced with a new one not reused or furbished. Router is using Firmware Version V7.2.6.31_5.0.24 which stating most current and I did a factory reset still same issue.
I used two pc's directly connected to the router and getting 500 to 600.
Looks like this is an issue with Orbi routers.
Aug 01, 2024Guru - Experienced User
v.31 has been well received and users have been posting problems with it. I'd revert to v.21. I ran my 850 on this and is very stable and gets to spec speeds for my 1Gb/50Mbps service.
I'd also try the RBR at a different location, if you have friend or family member that you could try the RBR at there place to see if the problem follows. If it does then you'll know for sure.
Can find possible good used RBRs on amazon, fleabay or shopgoodwill.
- SBstomper2Aug 01, 2024Aspirant
Its the orbi doing the same thing at my neighbors I am currently hooked up to an older router and its getting 575 to 600 which is still low and Spectrum is coming out in the morning to address that issue.
Thank you all for your help.
- FURRYe38Aug 01, 2024Guru - Experienced User
Ok, now you know.
Good Luck.
