stevecpa72
Sep 21, 2024Aspirant
rbr 850
I have a ORBI RBR850 with three satellites. I log in to the router and It shows that I am getting internet connection and plenty of speed (2.4G). When I log in to the app it shows no internet conne...
CrimpOn
Sep 21, 2024Guru - Experienced User
Some additional troubleshooting may be helpful.
Is it obvious that the system does have an internet connection, in the sense that a number of devices are connected to the system and are performing normally (web surfing, streaming video, reading/sending email, doing what they normally do)?
If this is the case, that points to a problem with the device running the Orbi 'app'. Perhaps it is not connected to the internet, either through WiFi or the cellular network. (Hint: has Anywhere Access been enabled on the Orbi app on this device?)
Is it always the same devices that appear to have network issues? If there a distinct pattern to the problems? Do they seem to be related to one of the satellites?
stevecpa72
Sep 22, 2024Aspirant
No I am getting internet and the ip address says it has internet. I think I am going to do a factory reset and see if that works. Such a pain. I am also getting significant disconnecting by devices. Thank you for your help
