ZOOShen
Nov 26, 2021Star
RBR 852 frequently disconnects.
I have been experience RBS connected devices disconnects from internet the every few minutes. I have two RBS 852 connected to the RBR 852. Both RBS are having the same problem. I am sure that I upgra...
Nov 27, 2021Guru - Experienced User
Be sure RBS have same version of FW loaded as whats on the RBR.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
ZOOShen wrote:
I have been experience RBS connected devices disconnects from internet the every few minutes. I have two RBS 852 connected to the RBR 852. Both RBS are having the same problem. I am sure that I upgraded to the latest firmware.
I come accross this forum, and few of use has experience same.
Anyone could help here?
