Beantowm111
Mar 04, 2023Apprentice
RBR 860 not showing satellites as wired
I have two rbs850 satellites wired to an rbr860 router. All works ok but the Orbi app is telling me they are connected by 5 ghz rather than wire. Tried plugging and unplugging but no change. Any guida...
Mar 05, 2023Guru - Experienced User
How are the RBS conected to the RBR? Directly behind the RBR or is there any kind of LAN switch in between?
Did you first wirelessly sync the RBS to the RBR then ethernet connect them?
What CAT# LAN cable are you using between the RBS and RBR? CAT6 is recommended.
Beantowm111
Mar 05, 2023Apprentice
Thank you - one of the wired satellites is showing up fine. The other is giving wired speeds but showing as connected by 5g daisy chain to other wired satellite. I believe house is weird mostly via Cat 5e but maybe Cat 6 in some places.
- FURRYe38Mar 05, 2023Guru - Experienced User
Turn OFF the working RBS and see what happens...
IF the one RBS thats showing up as daisy chain, and not wired, most likely a bad ethernet connection between the RBS and RBR, cabling or ethernet jack in home maybe bad.
It's recommended to use all one CAT# lan cable and not mix them.
