306Orbi
Jan 13, 2023Star
RBR 960E Rebooting every 2 Minutes
I updated to the latest firmware of My 3 year old RBR 960E Router two days ago and today my router started rebooting every 2 minutes. Worked with Netgear tech support - first hard reset the router b...
- Jan 15, 2023
Thanks for responding to my cry for help...
Turns out that one of my Araknis Switch (snap av) with OVRC (cluod management) was the culprit in this setup...
I attached a OVRC Wattbox cloud power controller to this switch and the switch got corrupted and all hell broke loose.
After the weekend of troubleshooting I took the switch of my network and all is stable.
I did roll back the firmware to October Version and let the firmware there..
So problem solved - it was not the ORBI but the Switch,
Jan 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Worked with Netgear tech support - first hard reset the router but no luck.
I then rolled back to one previous version firmware but problem persists.
Netgear told me to observe 24 hours and then discuss - the router is out of warranty...
Will appreciate any help on how to solve this issue..
- 306OrbiJan 15, 2023Star
- plemansJan 16, 2023Guru - Experienced User
Glad you got it figured out!
- FURRYe38Jan 16, 2023Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
