306Orbi
Jan 13, 2023Star
RBR 960E Rebooting every 2 Minutes
I updated to the latest firmware of My 3 year old RBR 960E Router two days ago and today my router started rebooting every 2 minutes. Worked with Netgear tech support - first hard reset the router b...
- Jan 15, 2023
Thanks for responding to my cry for help...
Turns out that one of my Araknis Switch (snap av) with OVRC (cluod management) was the culprit in this setup...
I attached a OVRC Wattbox cloud power controller to this switch and the switch got corrupted and all hell broke loose.
After the weekend of troubleshooting I took the switch of my network and all is stable.
I did roll back the firmware to October Version and let the firmware there..
So problem solved - it was not the ORBI but the Switch,
306Orbi
Jan 15, 2023Star
Jan 16, 2023Guru - Experienced User
Glad you got it figured out!
