Theobuck
Aug 03, 2023Apprentice
RBR placement
Our apartment has RJ45 ports in 4 rooms, but they terminate in the Master bedroom closet, where the Optical Network Terminal is located. I wish the design was diffrent but it what I have to work with...
- Aug 04, 2023
Probably.
Distance between a wifi router and other devices should be 3-6 feet.
Aug 03, 2023Guru - Experienced User
Maybe not idea however can work if you can connect the remote lan ports in these rooms to the back of the RBR:
- TheobuckAug 03, 2023ApprenticeDo you mean maybe not ideal?
- FURRYe38Aug 03, 2023Guru - Experienced User
Ideal. Recommended locations for the main RBR unit is out in a room that's well ventilated so signal travels well and has good coverage for devices that need to connect to the RBR, not just the RBS.
Sorry to keep using you as a sounding board.
The current location is in a medium size room where the door is often closed. It is my office, and if I am on a conference call (which is often), the door is closed.
The closet where this ONT is located is in a similar configuration and is smaller.
My office has a lot of electronic devices Monitors, PCs, and so on.
The closet would only have the RBR and a Bed Room TV on a far wall.
If I did move the router next to the ONT, would the backhauled satellites make up for any loss of Radio Signal?
