Bushcat748
Aug 06, 2024Aspirant
RBR Satellites connect but no internet
Hello, The RBR 750 is working. Just did the latest firmware update. But since then the satellites will not transmit internet. They are connected, just no internet being transmitted and/or being r...
- Aug 06, 2024
đ
Aug 06, 2024Guru - Experienced User
What FW version did you update with?
Did you update the RBS first then the RBR lastly?
Has a power off for 1 minute then back ON with the ISP modem and router and RBS been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- Bushcat748Aug 06, 2024Aspirant
Please excuse the ignorance.
Just updated via the app. So am assuming that was the router 750 not the rbs350 satellite.
The version is 7.2.6.31
so am assuming the rbs satellite needs firmware update?
how do I do that ?
- FURRYe38Aug 06, 2024Guru - Experienced User
There we are. Ok, RBS350. Sorry that v7 FW isn't compatible with the RBS350s so you'll need to downgrade the RBR750 back to v4 FW:
You'll need a PC or wireless PC/Laptop to download the RBR FW file to the PC and then log into the RBRs web page and send it to the RBR:
I'd disable the auto FW update option as well:
https://kb.netgear.com/000038662/How-do-I-enable-disable-auto-firmware-update
No idea if or when the 350 series RBS that are apart of the 650 series model system will be getting FW. They may not be.
Many thanks for your help!
will let you know how I get on or how I stuff this up further - lol
Yes power off has been done since firmware update.
even did a factory reset and set up new network
