Bushcat748
Aug 06, 2024Aspirant
RBR Satellites connect but no internet
Hello, The RBR 750 is working. Just did the latest firmware update. But since then the satellites will not transmit internet. They are connected, just no internet being transmitted and/or being r...
- Aug 06, 2024
đ
Aug 06, 2024Guru - Experienced User
What FW version did you update with?
Did you update the RBS first then the RBR lastly?
Has a power off for 1 minute then back ON with the ISP modem and router and RBS been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Bushcat748
Yes power off has been done since firmware update.
even did a factory reset and set up new network
