Bushcat748
Aug 06, 2024Aspirant
RBR Satellites connect but no internet
Hello, The RBR 750 is working. Just did the latest firmware update. But since then the satellites will not transmit internet. They are connected, just no internet being transmitted and/or being r...
- Aug 06, 2024
đ
Bushcat748
Please excuse the ignorance.
Just updated via the app. So am assuming that was the router 750 not the rbs350 satellite.
The version is 7.2.6.31
so am assuming the rbs satellite needs firmware update?
how do I do that ?
Aug 06, 2024Guru - Experienced User
There we are. Ok, RBS350. Sorry that v7 FW isn't compatible with the RBS350s so you'll need to downgrade the RBR750 back to v4 FW:
You'll need a PC or wireless PC/Laptop to download the RBR FW file to the PC and then log into the RBRs web page and send it to the RBR:
I'd disable the auto FW update option as well:
https://kb.netgear.com/000038662/How-do-I-enable-disable-auto-firmware-update
No idea if or when the 350 series RBS that are apart of the 650 series model system will be getting FW. They may not be.
- Bushcat748Aug 06, 2024Aspirant
Many thanks for your help!
will let you know how I get on or how I stuff this up further - lol
- FURRYe38Aug 06, 2024Guru - Experienced User
đ
THANK YOU !
Reinstalled v4 of the firmware for the router. Both Satellites connected and providing wi-fi signal.
Disabled the auto firmware update.
Thank you for taking the time to help.
