Bushcat748
Aug 06, 2024Aspirant
RBR Satellites connect but no internet
Hello, The RBR 750 is working. Just did the latest firmware update. But since then the satellites will not transmit internet. They are connected, just no internet being transmitted and/or being r...
- Aug 06, 2024
Bushcat748
Many thanks for your help!
will let you know how I get on or how I stuff this up further - lol
Aug 06, 2024Guru - Experienced User
- Bushcat748Aug 06, 2024Aspirant
THANK YOU !
Reinstalled v4 of the firmware for the router. Both Satellites connected and providing wi-fi signal.
Disabled the auto firmware update.
Thank you for taking the time to help.
- FURRYe38Aug 06, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
