GillOrbi
Sep 26, 2021Follower
rbr350 - daisy chain
HI, Does an ORBI RBR350 support daisy chain? I can see no option to enable it in the advanced wireless setup on orbilogin. I have a satellite that is furthest away that is losing 70% of speed and I thought daisy chain through a closer satellite to the router might help.
1 Reply
It does support it but its a built in feature that the router negotiates whether it should be ran in daisy chain or direct connect to the router.
What is daisy chain and how does it work with my Orbi WiFi System? | Answer | NETGEAR Support
