F2026880
Feb 22, 2021Tutor
RBR350 - Missing SSID on one device
Hi All, I'm very new to the Orbi system but i've got a curious problem on my laptop. All of my devices(a mixture of WIFI and Wired) are all working but my laptop will not show the WIFI network th...
- Feb 22, 2021
Mostly a driver problem or a out dated hardware problem...
Feb 22, 2021Guru - Experienced User
CHeck to be sure that the wifi adapter drivers on you PC is updated first. Most cases this is the cause of out dated drivers...
- F2026880Feb 22, 2021Tutor
I have updated the WiFi to the latest drivers but no difference. I'll go through the rest of the drivers to see if it makes any difference.
Is this a common problem.
- FURRYe38Feb 22, 2021Guru - Experienced User
- F2026880Feb 23, 2021Tutor
Thanks for the assistance. I did donwload the latest network drivers from the MSI website(and installed) but it didn't make a difference. However i right clicked the network adaptor within device manager and it updated and worked. All sorted now.
Just need to learn how to use this new system. I'm very impressed so far.
Regards
Richard
